RPM bouncing 50-60
Old Sep 12, 2016 | 01:20 PM
hrhoward's Avatar
Default RPM bouncing 50-60
Once in a while, maybe once or twice a week, the RPMs oscillate about 50-60 RPM. Accelerator pedal is held steady. Flat, straight road. A/C on or off. Going about 65 mph in this video. I can feel it but just barely. What could it be?
Old Sep 12, 2016 | 06:48 PM
ihscouts's Avatar
Tach is always related to the alternator but I've also fixed a loose connection behind the face card. Very easy to check once the binnacle's off. Tach could be loose/frayed alternator/tach wire. It could be something causing the motor to surge, drag or something like a belt tensioner loosening up. What condition is the belt in?
Old Sep 12, 2016 | 09:14 PM
jhmover's Avatar
Check the white wire that plugs into the alternator. My 96 was doing weird stuff and it was loose. I squeezed the female connector some to tighten it up, plugged it back in and it was fine for years.
Old Sep 14, 2016 | 12:12 PM
hrhoward's Avatar
Belt is a Gatorback with about 6000 miles on it.
I can feel the motor surging when this is going on.
I'll check out the alt wire.
Old Sep 14, 2016 | 04:02 PM
ihscouts's Avatar
Fuel filter canister been replaced? Fuel pump and sock filter? Crank sensor wiring condition? It's a small drop so it's not serious yet. I wonder about the fuel delivery or possibly an injector or it's connection. You could run some Techron through the fuel system to see if that does anything.
Old Sep 15, 2016 | 10:35 AM
hrhoward's Avatar
Fuel filter has about 6,000 miles on it also.
The fuel pump, according to the PO, was replaced about six years ago.
I pour a can of sea-foam in the tank every oil change. So far I have changed the oil twice but have run about four cans through. Two right off the bat.
No idea of the crank sensor wiring. I'll look at it while I'm r/r the rear universals.
I am going to get rid of the cats here shortly and use the resistor capacitor scheme for the post O2's.
Old May 24, 2019 | 03:26 PM
hrhoward's Avatar
Ok, so it's been a while since I last posted on this issue. Kinda have it narrowed down a little more. Recent work on truck has pretty much ruled out anything engine related.
It only happens in 4th, between 50-ish and 60-ish, not at highway speeds, 65+. Cruises right along at 75.
Thinking torque converter or valve body. Transmission doesn't have any electrics in it, right?
Old May 24, 2019 | 04:33 PM
ihscouts's Avatar
Shifts by pressure. Direct drive clutch or it’s control valve, torque converter control valve, Hysteresis valve sticking.....
Old Jun 9, 2019 | 09:58 AM
hrhoward's Avatar
ihscouts, thanks for the reply.
That's what I thought. Didn't think I read that section wrong and I didn't see any wires going to trans.
Changed fluid and filter while engine was out. That didn't affect surging though.
Going to fiddle with the kick-down a bit. My downshifts are a bit crisp.
frankh
Sep 13, 2016 05:25 AM
ESPN
Aug 24, 2012 08:55 AM
kean
Mar 3, 2009 07:28 PM
azazel_18_2
Feb 12, 2009 12:39 PM
DuplinDisco
Aug 7, 2008 04:34 PM
