RPM dropping
Old Mar 3, 2009 | 05:53 AM
kean's Avatar
Default RPM dropping
anyone knows why my rpm is dropping and sometimes works?
Old Mar 3, 2009 | 09:22 AM
okdiscoguy's Avatar
If you are talking about your tachometer (the thing that displays your RPM), then it is most likely your alternator going out. Check all of the wiring for corrosion and loose connection, then have your alternator tested.
The tach runs directly off your alternator
Old Mar 3, 2009 | 02:29 PM
Can you be more specific or did OK nail it?
Old Mar 3, 2009 | 04:17 PM
kean's Avatar
ill try to have the alternator checked
Old Mar 3, 2009 | 04:21 PM
kean's Avatar
oh is the alternator repairable? thanks
Old Mar 3, 2009 | 04:36 PM
usmc_mwroseberry's Avatar
If you are getting fluxuation while driving. And it feels like it is missing it is plugs and wires or it's coil packs. I had that problem and I had one bad wire.
Good luck,
Merritt
Old Mar 3, 2009 | 05:52 PM
Yes the alternator is rebuildable but youi can usually buy a good used one for much less.
www.roverlandparts.com
www.autosportsunlimited.com
Sorry, you are in the UK, these links do you know good.
I will leave them up as they might help someone else.
Old Mar 3, 2009 | 07:12 PM
kean's Avatar
ok ill check on it, what exactly do i test?amp?voltage? and what else?
Old Mar 3, 2009 | 07:28 PM
Check the voltage and the connections on the back of it.
Aus-trek
Oct 31, 2012 04:21 AM
willb285
Jul 24, 2010 04:54 AM
chargersfan
Aug 25, 2007 12:22 PM
tailchaser0527
Aug 14, 2007 12:13 PM
willb285
May 17, 2006 02:48 PM
