Shift Interlock lesson
Old Sep 16, 2015 | 04:47 PM
partsguru's Avatar
NAPA/ Echlin SL811 $24.95 (NO FREIGHT!) - on order today! Of course, my cost is less... Russ
Old Sep 17, 2015 | 04:21 PM
partsguru's Avatar
Got my switch in today and installed - working perfectly! With nothing to lose, I disassembled the switch to see if it was a problem and/or rebuildable. I found that the center plunger is just held in by a coil spring grabbing serrations on the shaft - so just pull hard and it comes out allowing the guts to pull apart once you get past the 4 tabs around the base. Once inside, I found that it is cleanable in an emergency, but I found out that one side of mine had arced the points and melted one of the springs (small). So, I feel confident that I found the problem (I'm knocking on wood!) and now I'll move on to the next thing... Russ
Old Sep 17, 2015 | 04:38 PM
ihscouts's Avatar
Cool, one down, many to go....... These become very reliable once you swim through all the neglect.
Old Jul 15, 2018 | 11:54 AM
BobE's Avatar
I had this happen to me yesterday and found a few references to the paperclip trick from fishEH - worked like a charm! THANKS FISH - best hack yet! Genius!
Once you think about it, it makes perfect sense why it works. Seems pretty "unique" that the 3rd break light is powered through the traces on the glass, but it does make it very convenient to jumper.
Old Jul 15, 2018 | 12:47 PM
rjlsierra's Avatar
first of all i need to say this,you guys are rock stars!!!,i always carry an extra switch cause been there! if you got a pic on where to place the paper clip on the third light connector to the defrost and then push the defroster button,i'm frickin stoked
Old Jul 15, 2018 | 08:43 PM
BobE's Avatar
A couple of pics of the aforementioned paperclip
Cargo door glass, passenger side, see other pic for blow up
paper clip jumps the two connectors - one is to the rear defroster traces, the other is to the 3rd brake light
Old Jul 16, 2018 | 06:47 PM
Johnny K's Avatar
Originally Posted by fishEH
Use that paperclip to jumper the 3rd brake light connector and rear defrost connector on the cargo door glass.
While in the drivers seat push the Rear Defrost switch and you'll be able to shift out of Park.
Ha ha ha! The ingenuity/nonsense required to keep these trucks a'runnin is why i love my Disco 1 and LRs in general! Wear it like a badge!
beyeker
Aug 11, 2015 05:47 AM
rappo999
Mar 8, 2013 11:37 PM
s10lowrider1994
Jan 19, 2013 09:54 PM
Dan Wallace
Jul 30, 2012 03:51 PM
msandona
May 6, 2010 05:46 PM
