Got my switch in today and installed - working perfectly! With nothing to lose, I disassembled the switch to see if it was a problem and/or rebuildable. I found that the center plunger is just held in by a coil spring grabbing serrations on the shaft - so just pull hard and it comes out allowing the guts to pull apart once you get past the 4 tabs around the base. Once inside, I found that it is cleanable in an emergency, but I found out that one side of mine had arced the points and melted one of the springs (small). So, I feel confident that I found the problem (I'm knocking on wood!) and now I'll move on to the next thing... Russ
I had this happen to me yesterday and found a few references to the paperclip trick from fishEH - worked like a charm! THANKS FISH - best hack yet! Genius!
Once you think about it, it makes perfect sense why it works. Seems pretty "unique" that the 3rd break light is powered through the traces on the glass, but it does make it very convenient to jumper.
first of all i need to say this,you guys are rock stars!!!,i always carry an extra switch cause been there! if you got a pic on where to place the paper clip on the third light connector to the defrost and then push the defroster button,i'm frickin stoked
Use that paperclip to jumper the 3rd brake light connector and rear defrost connector on the cargo door glass.
While in the drivers seat push the Rear Defrost switch and you'll be able to shift out of Park.
Ha ha ha! The ingenuity/nonsense required to keep these trucks a'runnin is why i love my Disco 1 and LRs in general! Wear it like a badge!
