Shifting to Neutral without Power?
Old Oct 31, 2021 | 10:48 PM
DiscoNewbe's Avatar
Default Shifting to Neutral without Power?
Anyone know how to shift the D1 to neutral when off and without power? Starter died so I’m unable to start it up to shift to neutral.
Thanks!
Old Nov 1, 2021 | 10:08 AM
logan_gibson's Avatar
Engine doesn't need to be running to shift to neutral.
Just turn to Pos II and then it will retract the lock when you press the brake.
Otherwise, its taking the shifter cover off to expose the lock under the bezel and tape - at which point its faster to slide under the truck and remove the linkage from the transmission to toss it in N.
Old Nov 1, 2021 | 09:37 PM
DiscoNewbe's Avatar
For some reason when the vehicle died it wouldn’t shift from park to neutral even with the key in position II.
the battery was tested and is fully functional
Nick4
Aug 30, 2018 01:29 PM
DROVER1984
Jan 23, 2014 10:19 AM
gman21
Feb 18, 2013 02:40 PM
DROVER1984
Dec 12, 2012 09:29 AM
maitai
Aug 28, 2010 02:40 AM
