Shifting to Neutral without Power?
Engine doesn't need to be running to shift to neutral.
Just turn to Pos II and then it will retract the lock when you press the brake.
Otherwise, its taking the shifter cover off to expose the lock under the bezel and tape - at which point its faster to slide under the truck and remove the linkage from the transmission to toss it in N.
