Shiftpoints on a 1996 disco automatic?
Old Sep 21, 2010 | 04:03 PM
blaze98's Avatar
Default Shiftpoints on a 1996 disco automatic?
What are the shiftpoints on a 1996 disco? My 2nd and 3rd gear shift at 3000rpm, is this normal?
Old Sep 21, 2010 | 04:42 PM
Danny Lee 97 Disco's Avatar
Are you pushing it or just easing along? It will vary depending on how hard you are pushing it, especially if it is going uphill under load,etc.
Old Sep 21, 2010 | 05:17 PM
Depends on how your shift cable is adjusted and how much throttle pressure you are applying.
Old Sep 21, 2010 | 05:29 PM
Spencerfitch's Avatar
Rave lists what it should be at.
Old Sep 21, 2010 | 06:12 PM
blaze98's Avatar
When I got it the guy that had it said they put a new transmission in it and didn't have it adjusted right so it wouldn't hardly go anywhere then he said he thinks he adjusted it to tight. If I take it easy it shifts at about 2500 but that's creeping from a stop 1 st gear seem to shift of it's 2nd and 3rd when I am kind of heavy on it it will go to 3000 unless inlet off the gas a little then it will shift around 2700
Old Sep 21, 2010 | 06:48 PM
Well put Mike, is there some info on adjusting the cable somewhere?
Old Sep 21, 2010 | 10:18 PM
blaze98's Avatar
Yes that would be very helpful
Old Sep 22, 2010 | 09:37 AM
I can't remember the procedure anymore, but the Rave should have it in it.
deleon_daniel@sbcglobal.net
Nov 29, 2010 09:56 AM
bartmac
Feb 22, 2009 07:02 PM
johnkbl
Aug 30, 2007 08:43 AM
imag
Oct 4, 2005 12:17 AM
topgear
Jun 18, 2005 12:29 AM
