So what did you do to your Disco today?
Old Nov 2, 2014 | 09:18 AM
  #3361
TGerman's Avatar
Default Playing with rear sunroof and still having HB wobble
My rear sunroof opened for the first time since I bought my '98 Disco. One day the switch just decided to work.... Now it will close, but not all the way. Upon inspection yesterday, one of the arms connected to the window is bent and the plastic "runner" that fits into the window position track is toast. What I've not figured out yet is why I can't open or close it manually, no matter what position the window is in. It seems the motor is bound. It will operate with the switch, but with an allen wrench it will not budge.
Still confused on the harmonic balancer. Water pump disintegrated last month. Replaced it, timing gears / chain, inspected oil pump, new fan and clutch. Installed HB and it had a bad wobble. Bought a used one and it too has a bad wobble. Has anyone used the services of The Damper Doctor in California? I want to rebuild one of mine. Does anyone have a rebuilt one or a KNOWN good one available?
Old Nov 2, 2014 | 01:14 PM
  #3362
ihscouts's Avatar
Are you sure you don't have a bent crank snout?
Old Nov 2, 2014 | 02:08 PM
  #3363
TGerman's Avatar
I've thought about that. I did attach a micrometer and turned the crank by hand. It didn't indicate it was bent. But, that was by hand, it may be a different story at idle+ speeds.
Old Nov 3, 2014 | 09:39 AM
  #3364
philwarner's Avatar
The sunroof motor is a worm drive so you can "help" it turn but you can't turn it with an allen wrench alone. I had the same problem with my front sunroof not closing all the way (and yes its little plastic sliders were toast too) and I had to take down the motor assembly and remove the motor and worm from the red gear in order to put it back up and turn it manually.
Old Nov 4, 2014 | 08:14 AM
  #3365
TGerman's Avatar
Got it closed all the way. Not sure what I did, but I'm going to leave it alone and put replacing some of the sunroof components on my to-do list. That's after I put on a rebuilt HB (hopefully that will cure the wobble), new shocks, front end components, adjust preload and wheel bearings, new radio, seat switches and about a thousand other things...........
Old Nov 6, 2014 | 06:04 PM
  #3366
TheGageinator's Avatar
. Changed my front diff fluid. Bought more oil and a hand pump to do the rear diff and transfer case tomorrow. Also got oil and an oil filter. Also got the disco inspected! .
Old Nov 7, 2014 | 07:56 AM
  #3367
TGerman's Avatar
I'm kind of lucky as far as inspections go. We're not required to have to pass an emissions test. But, by God, you're license plate lights better work and if you have wipers on your headlights (our old Volvo), the blades better be in good shape....
Old Nov 7, 2014 | 03:33 PM
  #3368
yeah i wish we didnt have emissions testing. it can be a pain. I live a little south of Dallas.
Did ALOT on the Rover today.
Changed spark plugs with Champion 322
Replaced rear Diff fluid
Replaced Transfer case fluid
Changed engine oil and fliter
Greased prop shafts and joints
cleaned IAC and had to replace a screw
Repaired window control ECU
Old Nov 12, 2014 | 12:25 AM
  #3369
USNAVYORDNANCE's Avatar
Got some catching up to do here. Lol. Repaired leaky head gasket, replaced fan clutch (oem), hard wired fans to ignition source (switched), 180 t-stat, double coolant flush (4 day process) and 150 psi blowout of coolant system, engine oil flush and changed fluid/filter (lucas oils), added lucas trans additive to trans and tcase (shifts good, looks good, will change soon), changed spark plugs and changed driver side window motor. This rig was in decent shape. Replaced a few vacuum lines, clogged pcv and cleaned all the air fuel sensors. Runs and shifts great. 4x4 engages and diff lock works amazing. Needs paint and will either go with Coyote or olive drab? All for now, carry on..
Old Nov 12, 2014 | 08:21 PM
  #3370
MM3846's Avatar
checked the timing on my truck after driving around dealing w spark knock under load on the highway, managed to somehow short out my alternator. luckily, it was still under warranty and the parts store had one in stock.
gonna check the timing and vacuum advance again tomorrow... i think i was somewhere around 10 BTC, which was way too hot.
