So what did you do to your Disco today?
Old Oct 30, 2014 | 03:07 PM
  #3351
EricTyrrell's Avatar
Removed fuel filler door. Painted filler interior silver since it's steel. Replaced cap with a locking cap. I like the defender/early RRC look and simplicity. No longer do I have to give my keys to a gas attendant.
Added rubber diamond plate to bumper to protect powder coat and give traction when used as a step.
Old Oct 30, 2014 | 11:45 PM
  #3352
fishEH's Avatar
WTF did you do to your rear windows!!!!??? And why?
Old Oct 30, 2014 | 11:52 PM
  #3353
Had to drill the spot welds and take them out anyways to do the D2 lights. Then decided I didn't want or need them, and didn't feel like buying new seals. Privacy is a bonus.
Old Oct 31, 2014 | 12:48 AM
  #3354
Sir Axlerod's Avatar
I did a similar mod, because the plastic clippy that locks it shut broke...
Atta boy!
Old Oct 31, 2014 | 06:07 AM
  #3355
MM3846's Avatar
I'm just noticing this now.... did you sand away all your paint to bare aluminum?
Old Oct 31, 2014 | 08:13 AM
  #3356
fishEH's Avatar
He did. Also swapped in D2 rear corners.
Eric, how hard was it to pull the D1 corner pieces off? Did you have to cut through spot welds? How did you secure the D2 pieces? My drivers side has a dent in it and I'm wondering how involved replacing that bit may be. Thanks!
Old Oct 31, 2014 | 11:16 AM
  #3357
Only took a few months of spare time
Old Oct 31, 2014 | 11:30 AM
  #3358
MM3846's Avatar
i'm waiting for mine to do it naturally. hood is almost 1/4 of the way there.
Old Oct 31, 2014 | 11:39 AM
  #3359
If the corner panel wasn't spot welded to the side panel it'd be easy. You could unscrew the corner and cut the seam to the side panel, but then I'm not sure how you'd attach a new corner panel to the side panel. Maybe adhesive.
I chose to remove the side panel, drill out the spot welds, and rivet the D2 corner on using the drilled spot weld holes.
Removing the side panel involved interior removal, removal of a dozen bolts, drilling rivets, and the dreaded black panel sealer goo which his used thick and liberally. Then had to remove the glass to drill and rivet the seam.
Old Oct 31, 2014 | 01:42 PM
  #3360
fishEH's Avatar
Hmmm, Ok. Doesn't sound outside the realm of possibility. My interior is already gutted. The bigger pain would probably be trying to source that part from a junk yard....
