So what did you do to your Disco today?
Old Oct 26, 2018 | 01:39 PM
  #4211
denverdisco1's Avatar
Originally Posted by fishEH
Started tearing down the 14CUX 4.6 engine I bought a couple years ago. Was planning on doing a full rebuild but the condition of the internals left me pleasantly shocked!
How many miles on that motor?
Old Oct 26, 2018 | 05:48 PM
  #4212
Disco97ninja's Avatar
Default Master cylinder done
Have pressure now ,,, yip hee , just got done bleeding brakes some air and perfect bleeders , still had rubber caps on lol , I will repeat bleeding brakes in a few days as I'm making sure all bad fluid or air is out , now to go fill this tank up with gas and take her on a test drive , old master cylinder rubber was junk touch it and it fell apart , thanks denverdisco1 for the advice one caliper had alittle water in it but mostly air I think fresh Dot 4 in her now and will repeat bleeding once or twice more til I get all new dot-4 coming out
Old Oct 27, 2018 | 05:27 PM
  #4213
aemnky606's Avatar
Replaced all 3 transmission lines and the cam position sensor with new o-ring.
Old Oct 30, 2018 | 11:29 PM
  #4214
rickroverover's Avatar
removed the entire center dash to remedy a stuck heater cable. replacing the light, dash center with a better - unbroken one.
last few months had the front seat reupholstered with material from the back seat from the boneyard.
Old Oct 30, 2018 | 11:43 PM
  #4215
Originally Posted by aemnky606
Replaced all bushings on the truck. Took a 20 ton press to knock them all out but not that bad of a job. No snapped bolts, but did spray them every night for the week leading up to the project.
Can you rate the change in the way the truck feels? Was it worth it? Like a new ride or just marginal difference?
Old Nov 3, 2018 | 09:15 PM
  #4216
aemnky606's Avatar
I would say after changing 22 year old bushings there is a night and day difference. I had quite a bit of body roll before and now it is quite firm. I have now noticed now if I hit a bump or I'm off roaming my back gate will clunk. I'm not sure how to go about fixing that.
Old Nov 3, 2018 | 09:43 PM
  #4217
Icannap1's Avatar
Clean and prepped.
Old Nov 4, 2018 | 11:22 PM
  #4218
Icannap1's Avatar
Happy with the result 3 coats of Herculiner 1 gallon kit.
Old Nov 5, 2018 | 07:54 AM
  #4219
These trucks have sloppy feeling brakes as they are, a little air or water create a little shock absorber and makes it worse.
Old Nov 8, 2018 | 02:53 PM
  #4220
Default Brakes had gunk in lines
Had to power bleed them today ! Not much air but brake fluid looked like dirty beer and debris was in it pedal back to 100% again and clear dot-4 only comes out now , when my master cylinder went out it must of had junk from the rubber seals that cumbled down into my lines , when old one was off if you touched the rubber it just fell apart , hopefully it will work for along time now since it's all fresh rubber and dot-4 ...
