So what did you do to your Disco today?
Old Dec 14, 2012 | 08:14 AM
  #901
fishEH's Avatar
Originally Posted by SSL9000J
Lookin good! Possibly a dumb question: did you have to disable/remove the hood latch in the cabin to install the hood pins?
People usually install hood pins because the stock cable/latch fails. I guess you could install hood pins in addition to a working cable/latch but I don't see the point. So yes, I would remove the stock latch. However, I kept the spring and secondary catch when I installed my hood pins.
Old Dec 14, 2012 | 04:53 PM
  #902
honda50r's Avatar
90% done with my months long project a lot of you know about. I have to find a 22 mm for the crankshaft pulley, a torque wrench to handle 125+ foot pounds, install the radiator, and wait on a new expansion tank from Marty. So close!
I hope it's not my bearings causing all this...
Old Dec 15, 2012 | 02:01 PM
  #903
d1eddie's Avatar
Default went to the farm supply store came back with more then i wanted
so unloading the bags of feed and rice hulls i started to see mice, the first one , then 3 more i was kinda wondering , any idea how to get them out of my dash before they eat my wires, i was going to go find sum loal mud holes but now my rover is parked out side, doors open in hope to get the mice out of the dash...
my uncle had a car that got fried due to nibbling mice on his ecu wires ..
going to take the jeep to the store to get mice traps , such a worthless start of the day..
Old Dec 15, 2012 | 02:23 PM
  #904
CUpgt's Avatar
Turn a rat snake or corn snake loose in it!
Old Dec 15, 2012 | 04:53 PM
  #905
pkppunk's Avatar
Moth ***** is what I have used in my cars when I store them and never have had a problem
Old Dec 17, 2012 | 06:20 AM
  #906
JC Speiser's Avatar
I started spraying carb cleaner around the vacuum lines to check for leaks.
When i ran out i switched to wd-40.
couldn't find any vacuum leaks ( yay for me ) and wound up using 2 large cans of wd-40. First I sprayed the ends of the vacuum lines one at a time...and just couldn't leave the middle dirty! Had to spray the middle.
The I sprayed the electrical connections...and it went from there.
I probably just screwed the pooch didn't I ?
Old Dec 21, 2012 | 04:02 AM
  #907
dragonhead's Avatar
Just had all four shocks replaced today and voilà...no more death wobble! My truck drove home at 75 mph, a speed it hasn't seen for over a year now. Thanks to Paul, my mechanic and brother. Now to deal with that whining water pump...
Old Dec 21, 2012 | 11:13 PM
  #908
d1eddie's Avatar
Talking got them in the mail
thanks to the great people at treadwright.com i got my set, and with my luck fedex lost one tire, don't know how u lose a huge chunk of rubber, but all that aside ,they say there sending me out my lost one.
i was surprised, and happy to find that i do not need to trim with my 265/75R16 GUARD DOG M/T (E) 32.2"x10.5", but i will agree with every one that i will need better gearing for up hills on the freeway...
quick 50 mile review
tires are not to loud but do hum on the freeway
tires have great grip for stopping better them my coopers s/t .
ill do a trail review soon with pictures if i can get some one to take pictures..
Attached Thumbnails So what did you do to your Disco today?-wp_000345.jpg   So what did you do to your Disco today?-wp_000348.jpg
Old Dec 22, 2012 | 01:07 AM
  #909
BD_LR4's Avatar
Installed my new HD Tie Rod, Drag Link and Steering Damper Relocation Kit! Finally time to get some new tires
I also had an issue with my light switch - had headlights, but no aux or dash lights. Picked up a used unit at Pick N Pull for $12.99. Installed that and now everything works properly again.
I'll be posting some picks up in the mod sections once I get the new tires installed.
Old Dec 27, 2012 | 10:26 PM
  #910
fishEH's Avatar
Got myself a daily driver.
