Speed!!!!
Speed!!!!
Well this is a strange one.... (is there anything else with this truck?? lol)
So I think i may have identified the issue with why the speedo/performance gets wierd....
On my tablet bluetooth adaptor it's reading ECU speed its anywhere from 30-60mph HIGHER than GPS and actual speed...
Interesting to note is the speed on the speedo is accurate ...... Somethin aint adding up here
Any thoughts? ideas on what to check on? ....
ABS is out and has been on mine for a bit. Before today the difference between ECU and vss was only 1-3mph, well since i been checking...
And today is the first day I've had an issue in a while
Ironically the p1179 dissapeared now
D1 gets from VSS, D2 averages the wheel sensors. VSS begins to fail, and eventually makes ECU think you are approaching takeoff velocity, and it will cut out injectors and spark. Cluster has another board inside that takes samples from the VSS to drive the speedo. I suspect that the data sampling or smoothing rate of the speedo board is different from the ECU, the ECU might sample fewer pulses and as such be subject to quite an impact of "jitter" of the signal. I think you can have a flakey VSS and the speedo not show it dramatically.
