Speed!!!!
Old Sep 26, 2013 | 06:18 PM
nuclearw's Avatar
Default Speed!!!!
Well this is a strange one.... (is there anything else with this truck?? lol)
So I think i may have identified the issue with why the speedo/performance gets wierd....
On my tablet bluetooth adaptor it's reading ECU speed its anywhere from 30-60mph HIGHER than GPS and actual speed...
Interesting to note is the speed on the speedo is accurate ...... Somethin aint adding up here
Any thoughts? ideas on what to check on? ....
Old Sep 26, 2013 | 07:59 PM
Bad VSS (vehicle speed sensor)
Unplug it, re-test your speed.
Old Sep 26, 2013 | 08:44 PM
nuclearw's Avatar
doesn't the VSS control the speedo as well?
Old Sep 26, 2013 | 10:05 PM
OverRover's Avatar
+1 on the bad VSS...........
Discovery speed sender
Old Sep 26, 2013 | 10:28 PM
TOM R's Avatar
You can rebuild it for less then $1 there is a thread on it I did mine it is simple
My speedo is 5 fast but computer is dead on with GPS, are we sure both read from vss and not one running off ABS wheel sensors?
Old Sep 26, 2013 | 11:32 PM
nuclearw's Avatar
Hmmmm.... possible i suppose ... they gotta be doing somethin different or my ECU is hosed readin that much more than whats real...
ABS is out and has been on mine for a bit. Before today the difference between ECU and vss was only 1-3mph, well since i been checking...
And today is the first day I've had an issue in a while
Ironically the p1179 dissapeared now
Old Sep 27, 2013 | 01:08 AM
D1 gets from VSS, D2 averages the wheel sensors. VSS begins to fail, and eventually makes ECU think you are approaching takeoff velocity, and it will cut out injectors and spark. Cluster has another board inside that takes samples from the VSS to drive the speedo. I suspect that the data sampling or smoothing rate of the speedo board is different from the ECU, the ECU might sample fewer pulses and as such be subject to quite an impact of "jitter" of the signal. I think you can have a flakey VSS and the speedo not show it dramatically.
Old Sep 27, 2013 | 08:43 AM
TOM R's Avatar
Vss it built cheap with plastis washers not bearings it is probly bad, plastic wears out causing too much shaft play then it starts to bounce around in its case hitting the sides
Old Sep 27, 2013 | 09:08 AM
EricTyrrell's Avatar
Yes I can confirm this.
soupdogg
Sep 25, 2007 12:49 PM
Kiwi Mike
Mar 2, 2006 07:32 AM
garover
Apr 3, 2005 01:14 AM
sdunham44
Feb 13, 2005 11:42 AM
KENWOOD
Audio/Visual Electronics
Jul 11, 2004 12:10 PM
