Stalls when put into gear. Any ideas!!!
Old Mar 30, 2013 | 07:35 PM
discoverdave's Avatar
4wd High
The plugs are a little white. I’m in the processnow of draining the transmission. Hopefully it's not the torque converter!!!!!Will trans seafoam clean that out if it is clogged up??
Old Mar 30, 2013 | 09:51 PM
Fluid circulates in the transmission, including the torque converter. So a Seafom tranny treatment gets it all, but it is a solvent, so some gunk is removed and some stays behind.
Old Mar 31, 2013 | 08:36 PM
4wd High
Ok after the transmission flush it still stalls.Although if I put it into neutral give it some gas then put in to reverse ordrive she will move and drive!!! Not great but drive none the less. Was able togo get some beer " this is driving me to drinking lol" still have touse two feet break and gas. Still stall if I just let my foot off the gas.
Old Apr 2, 2013 | 09:49 PM
4wd High
Thank you for all the help by the way.
Update. After another transmission flush, cleaned the MAF, removed the plenum housing cleaned every thing I could. Running much better then it was. However it will still stall after 30 seconds or so of sitting (stopped) in drive or reverse. It is drivable and running good when moving. On the Torque program (off the OBD reader) at first stop RPM is at 750 starts dropping after the 30 seconds. The engine load is at 22% at first stop and continues to rise to about 38% when the engine stalls. Ideas??
Old Apr 4, 2013 | 10:02 PM
jfall's Avatar
Check for pending codes.
Your fuel pump may be just hardly working.
Also -
Sounds like a vacuum leak.
Check all vacuum lines.
There is a line from a valve cover to the intake. It goes bad.
Brake vacuum?
For an engine which is suffering with no power, you have to have codes..
Old Apr 4, 2013 | 10:47 PM
4wd High
Well I’m sure it is the fuel pump as it went outtoday had a nice tow truck ride. I’m looking at replacements. Seems thatmine has advance evaporative loss system. Two plugs go into it. All I seeonline are pumps w/o advance evaporative loss. Will one of these work??
Mikeyboi
Freelander
Mar 4, 2015 08:47 AM
glassman66
Jun 22, 2012 09:37 AM
primesuspect
Dec 2, 2011 10:34 PM
freelanderjames
Freelander
Dec 24, 2008 10:18 PM
theworks001
Dec 8, 2008 09:47 AM
