Start Dichotomy
Old May 5, 2014 | 01:00 PM
WaltNYC's Avatar
Originally Posted by MonteroMan
So today I have decided to - until I have installed new injectors and new inlet manifold gaskets - I shall release the fuel pressure in the fuel injector supply gallery as well as the air pressure in the fuel tank each time after turning off the engine. I tested it a number of times during the day and it works well; it is a good interim method to prevent over-fuelling of a warm engine at the next start-up.
Well if that works I'd check the gas tank vent line which I believe runs parallel to the filler line.
Old May 5, 2014 | 01:21 PM
EricTyrrell's Avatar
Please see this to retrieve any OBD codes:
Land Rover Troubleshooting: retrieving fault codes
Also, see this: https://code.google.com/p/rovergauge/
This program can interface with you 14CUX ECM and display engine temperature, road speed, engine speed, and other details, using meters and gauges. This data may be very helpful in diagnosing your troubles.
Old Jun 10, 2014 | 02:26 PM
MonteroMan's Avatar
Default Stupid vehicle
Rpms are forced a lot higher by dumping the clutch maybe
Would have been a valid point, but it starts at the first half-turn of the wheel - in fact engine is turning over slower than the starter.
Replaced the coil, and fitted ANOTHER ignition amplifier module (this time a Luca OEM.
Immediate starting, perfect running, exactly correct and smooth idling.
For a week - and dead as a doornail. Tow starts immediately.
Then even that failed. Dead. No fuel pressure.
Removed fuel pump and ran it with alcohol from a battery. Squirts a one yard stream.
Put the fuel pump back and it starts immediately and no issue whatsoever.
For a week, and dead as driftwood again - not even towing can start it.
Work on it, try and try but zero result.
Bridge the impact switch. Imediate start and smoother than ever running.
For a day? Two? Another week and then will fail on me out in the boondocks?
Darn stupid vehicles - simply read all the similar starting issues on this forum...
snads
Dec 6, 2014 02:42 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
