Steering gear adjuster lock nut
Old Aug 25, 2012 | 02:17 PM
txjag1023's Avatar
Default Steering gear adjuster lock nut
Well, been looking for a while now, and have had no luck finding one outside a rebuild kit. My gear is good just the seal on the bottom of the lock nut is damaged and fluid leaks out. Anyone know where you can get one alone without having to buy the rebuild kit for the thing, its for my 98 LR LSE, tried the stealership but they want to sell the entire kit for like $300.00.
Old Aug 25, 2012 | 02:54 PM
Does it leak as long as you keep the nut tight? If it doesn't then you might do what I did for a friend, tighten it down, degrease the entire top of the cap and use lots of JB Weld to keep the nut tight and stop the leak.
Old Aug 26, 2012 | 07:57 AM
txjag1023's Avatar
It's been cleaned and tightened down fully, it doesn't leak outside the nut, but it leaks between the threads on the shaft directly out the top, though about using so high pressure thread sealant on the threads itself to see if that does the trick until i manage to get a new nut or buy another kit, guess having extra parts isn't to bad an idea
Old Aug 26, 2012 | 08:51 AM
Might look at some teflon tape as one possibility.
Old Aug 26, 2012 | 10:24 AM
txjag1023's Avatar
Ok, came up with an idea an hour ago, and so far it's working great, will wait and see before i say it's fixed, but i made a gasket with a sheet of material for the bottom of the nut, then i used Some 10,000psi Teflon thread sealant from home depot, stuff was like peanut butter but it also acts like anti seize, then put a few drops of JB weld on the outer edge of the nut to make sure it doesn't move, torqued to spec and it's held for 15 miles driving so far, have a lot to do today so will see if it is still good tonight, thanks for the help though I do appreciate it
wheelgarage
Jun 5, 2013 02:10 PM
BrandonS
Dec 17, 2012 09:55 PM
brianex
Mar 6, 2011 06:41 AM
alanski
Jul 1, 2010 08:25 PM
Coory
Feb 18, 2007 02:08 PM
