Steering wheel points wrong direction.
Old May 15, 2014 | 04:26 PM
populist's Avatar
7th Gear
Default Steering wheel points wrong direction.
While driving straight ahead, the top of the steering wheel on my '97 points resolutely to 1:00. Now, I don't give a sliver of lizard **** which way the wheel points, but this is a new development and I just want to be sure it isn't, uh, pointing to a real problem.
The truck steers great and tracks straight with no problems. I put in TrueTrac diffs front and rear a couple months ago and gave them their first real workout this past weekend. They of course make the truck want to go straight, so I'm wondering if they may also be masking an alignment issue or some other problem? If so, would this result in uneven wear on the steering components, etc?
Old May 15, 2014 | 10:25 PM
XCELLER8's Avatar
did you hit anything during the "workout" ??, you may have bent the drag link a little.
Old May 16, 2014 | 08:31 AM
claudio413's Avatar
slide off the joints on the steering linkage where it meets the steering gearbox, center the wheel and reconnect it.
Old May 16, 2014 | 08:33 AM
MM3846's Avatar
thats pretty much the worst way to fix the problem. either the alignment got knocked out or the drag link is bent.
Old May 16, 2014 | 09:33 AM
populist's Avatar
7th Gear
Not that I specifically recall (but, then, I was probably averaging about 1.3 mph), but there would have been plenty of opportunity. That would definitely make sense given the timing. Thanks!
Old May 16, 2014 | 09:39 AM
drowssap's Avatar
thats pretty much the worst way to fix the problem. x2
Old May 16, 2014 | 10:03 AM
Paul Grant's Avatar
Time to crawl under the truck to take a look.
wrongway1
Jun 7, 2014 09:16 PM
novavon
Jun 28, 2010 12:31 PM
rover_boy
Feb 9, 2010 07:10 AM
BoostedAudi
Mar 16, 2007 09:39 PM
03se3
Freelander
Jun 2, 2005 04:07 PM
