Stock fog light switch question
Old Oct 21, 2012 | 04:31 PM
CUpgt's Avatar
Default Stock fog light switch question
Today I installed some Hella 500 fogs and i used the stock fog light wiring and switch. Question is...does anyone know how to modify the stock fog light switch to work independently of the headlights? I spliced a cut and spliced a wire on my car to enable the use of the fogs with just the running lights a few years back. Anyone know how to do this on the disco?
Old Oct 21, 2012 | 06:27 PM
Switch by itself won't handle those amps for long, a relay controlled by it would be better.
Old Oct 21, 2012 | 07:28 PM
CUpgt's Avatar
Doesn't it have a stock relay? I just want to be able to turn on the lights whenever i want regardless of headlights
Old Oct 21, 2012 | 07:32 PM
CUpgt's Avatar
Would a hot wire from the battery to the switch not accomplish this?
Old Oct 21, 2012 | 09:46 PM
Here is the stock wiring, with a relay. But does not link to head lights?
File Type: pdf
Old Oct 21, 2012 | 10:10 PM
fishEH's Avatar
Hellas 500's should be fine on the stock switch/wiring. Anything larger and I'd run a separate relay and wiring.
If you're really worried about it wire the switch to close ground instead of hot.
abran
Oct 1, 2013 09:09 PM
PJRover
Mar 9, 2013 10:18 AM
ebg18t
Mar 1, 2012 07:21 PM
Princess
May 28, 2009 10:47 AM
Kraftyz51
Aug 14, 2007 04:59 AM
