Stock switch wiring advice
Old Jan 14, 2014 | 10:13 AM
antichrist's Avatar
Originally Posted by fishEH
Question though. Why does the winch controller not need relays? Bigger wiring, higher rated switch??
You mean the stock controller? They are typically wired with #14 or #16 wires and at least a 10 amp switch.
Old Jan 31, 2014 | 08:34 AM
dusty1's Avatar
Fish, did you get this figured out? If it's not too big of a pain, I might try it on the rear. It would be nice.
Old Jan 31, 2014 | 08:44 AM
TOM R's Avatar
Yes he wired the switches to relays
Old Jan 31, 2014 | 09:05 AM
dusty1's Avatar
great. now I can make another fire hazard, to the rear hook up. oh boy
Old Jan 31, 2014 | 09:09 AM
fishEH's Avatar
Correct. The stock Volume Up/Down buttons closed ground. I cut those two wires and one is power in to the switch and the other is power out to the relay.
I'm about to use the stock FOG light switch to control a Rigid Dually reverse/work light in the back. I'll be using a relay for that as well.
Old Jan 31, 2014 | 09:20 AM
dusty1's Avatar
all the d1 switches are interchangeable, with one another, correct? i can fit those volume switches in my ashtray bezel? just using one spot with a cruise switch now, for compressor.
Old Jan 31, 2014 | 10:23 AM
fishEH's Avatar
Yes and no.
Yes because the bodies are the same shape and they'll all basically fit in eachother's spots.
No for two reasons.
1) There are tabs on the switch bodies and not all will line up with eachother. This can be remedied by cutting off the tab that doesn't line up with a razor knife.
2) The switches at the top and bottom of the instrument surround have extra plastic molding for finishing.
Old Jan 31, 2014 | 11:21 AM
dusty1's Avatar
"so you are saying, there's a chance"
I will dig out my box of d1 switches and give it a go.
worst that could happen, is i slit my wrist with a razor knife.
LandRoverChic
Nov 11, 2014 04:54 AM
DiscoSux
Nov 17, 2010 09:46 PM
fasterdammit
Apr 21, 2007 03:05 AM
ensign42
Apr 9, 2007 01:46 PM
ensign42
Audio/Visual Electronics
Apr 1, 2007 06:03 PM
