Strange Fuel Rail
Is the fuel rail just an open tube or is it more complex? I've noticed when I replace the FPR or an injector, it seems to lose pressure and gas comes pouring out as expected, but when I remove another injector or open the pressure valve, more gas and pressure is released.
Example 1: I removed the FPR for replacement. Gas came pouring out as expected. Then I hooked up fuel pressure gauge, expecting no spray because the pressure should have been released already from disconnecting the FPR, but it sprays fuel.
Example 2: Earlier I replaced the injectors. Each injector I removed released fuel as if it was under a small amount of pressure. You'd think removing one would let all the fuel and pressure go from the rail at once.
Any ideas?
Any ideas?
on
Seems like you would have whatever volume is contained within the pressurized line to deal with then it should be basically empty from fuel pump forward as long as fuel pump is kept off. So after the inital amont drains or sprays out that shold be it. If it is only partially drained whatever is left would leak as long as there is sufficient pressure in the line. It may take longer to vent all the pressure off than what you are allowing.
JumPeR04
04-07-2011 09:52 PM
JumPeR04
04-01-2011 04:15 PM
