Stubborn exhaust gasket keeps busting
Old Oct 8, 2017 | 07:53 AM
RedRovin''s Avatar
Default Stubborn exhaust gasket keeps busting
The exhaust gasket on my #8 cylinder keeps busting every 2 months and I can't figure out why... I keep it torqued to spec and was checking weekly. The bust is always in the same spot (top bolt hole). I tried the flimsy metal gasket and it happened as well. Any creative ideas to keep this thing from breaking?
Im to the point that I can change a gasket out in under 10 minutes...
Attached Thumbnails Stubborn exhaust gasket keeps busting-20170918_173050.jpg
Old Oct 8, 2017 | 01:10 PM
Icannap1's Avatar
Try doubling up the gasket on that port and see if that helps.
Old Oct 8, 2017 | 01:29 PM
RedRovin''s Avatar
Just realized i forgot to add picture. It's now added.
I'll give it a try when I order more. I'm down to my last gasket
Old Oct 8, 2017 | 02:40 PM
aemnky606's Avatar
Check your motor mounts. I had the gasket between the headers and y-pipe blow out. I replaced the mounts and still going strong.
Old Oct 8, 2017 | 05:18 PM
ihscouts's Avatar
I like the motor mount suggestion. Have you checked the flange face for square?
Old Oct 8, 2017 | 07:33 PM
RedRovin''s Avatar
Motor mounts are new as of last year. I haven't checked for square because I figured the bolts would square it up... silly me I guess
Francopacks
May 31, 2014 12:41 AM
gbob
Jun 14, 2013 02:52 PM
calebbo
Dec 12, 2011 09:40 PM
kenk
Jun 10, 2011 08:45 AM
Prepilot_3ck
Jul 9, 2009 09:53 PM
