Stuck engine. Need advice!!
Old Jan 3, 2011 | 12:09 PM
johnkbl's Avatar
Default Stuck engine. Need advice!!
Hello guys
Had a problem with my disco.... Forgot to change the oil..
Well.. I was driving it and the engine stopped working without any weird sound, any overheating or oil lamp signal.... it just turned off as if you would have done it with the key.
Hauled it to my mechanic and he took the oil pan from the engine and started checking the state of the piston and the crankshaft. Everything is Ok: all the pistons are not stuck. Somehow the crankshaft is stuck.
He will take out the engine today, but I would like to get something about your experiences.
What could be? Something inside the timing plate? Do I need to remove the complete engine to check it?
Thanks!
Old Jan 3, 2011 | 12:16 PM
hilltoppersx's Avatar
why do you think it is the engine the failed? was there any oil in the truck? what year is it and what is the mileage on the truck?
Old Jan 3, 2011 | 12:25 PM
johnkbl's Avatar
It had oil, but was in very bad conditions. I do not use the truck very often, and actually I had already purchased the new oil to service the engine while it died. The car is a 94, 3.9 and has about 170,000 miles on it.
As far as I know, the automatic gearbox can not stuck the engine... that's why I think it is the engine.
Old Jan 3, 2011 | 04:10 PM
For the value of the truck, you have 2 options, buy a used engine and have it installed or sell your for scrap, cause it will cost too much money to rebuild your engine.
Old Jan 4, 2011 | 11:51 AM
Danny Lee 97 Disco's Avatar
At that age and miles, I would be looking around for a different engine or even a different vehicle.
Old Jan 4, 2011 | 02:11 PM
I'm with Danny. Not sure how difficult it is to find trucks down there but I would look for a Defender or another Discovery 1.
Old Jan 4, 2011 | 02:56 PM
johnkbl's Avatar
Default Maybe new engine
Well....
My mechanic is taking out the engine just to check what happened. This kind of repairs are relatively cheap if you compare the price with the prices you are used to pay in the USA.
Also, as far as I know, some Chevy engines have the same parts than the Rover engine. Depending on the damage, it may be cheap to repair.
In parallel, I am evaluating to replace the engine and install a Isuzu diesel or something similar. If I do that, then I will have my disco for at least 5 years more.
HawesEA2
Dec 17, 2016 09:47 AM
powderhound
Jul 7, 2014 10:51 AM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
smyevich
Aug 31, 2006 01:31 PM
