Sway bar bushings question....
All the other bushings seem ok. Just the sway bar bushings (the ones that mount the bar to the chassis) are quite worn.
Jacking up the end would be helpful, but not necessary. I changed mine without much trouble, jacking it up just gives you a little more room to work. They were really tight getting in, and getting the strap back over the new ones, but just ignore that. I found that if I got the strap mostly in place, then got one of the bolts in good, I was able to wiggle it a bit to make sure it was in line and put the other bolt back in. Took me maybe an hour, but I was in no hurry.
I sold all the kits I had made. I don't really plan in making any more. All the parts can be had easily enough though. RovahFarm has the bushings. The rest of the hardware van be found at your local hardware store.
If you have a lift lose the bars the front hits the drive shaft offroading and the rear links can invert and jamb forward causing issues I had these happen, the ride is better without them when lifted IMO I was very resistant to everyone saying remove em then gave in and glad I did
Sell you mine, sitting in scrap plies at dads
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
Speed racer
11-11-2009 09:44 AM
Mountain_Rover
06-05-2009 10:45 PM
