Sway bar disconnects or just no sway bars???
yeah... I noticed that later. I got to this thread originally by googling "Discovery 2 Rear Sway Bar Disconects" and ended up in te D1 section unaware. I know some of the people in this section have both, so I was hoping someone would be able to answer. I'll try again from scratch on the "other side" ... thanks.
You will gain a lot more out of the rear as the sway bar limits how the a-rm "tranglulated" 3-link works - unlike the front where the radius arms axle end bushings controls how much the axle can move..
quick disconnect - discovery series II Good info on before and after way bars
I hope I don't get chastised for reviving an old thread, but I'm curious, do you need limiting straps and/or spring retainers + cones? I've heard people say they damaged shock mounts because the limiting factor is the shock.
edit: I have a D2 and found this thread with the related scroll feature, however I think the question about the shock limiting trace applies to both models.
To answer your question I would recommend rear spring retainers if you have a lift and no sway bars. It will keep the coil spring from falling out on full articulation. My 97 XD has no sway bars F/R and I have a 3inch lift on it. At full flex the coils unseat and without spring retainers the coils would fall out and jam between the tire, and the coil perch/mount.
