Sway bars on a D1, 1996
Old Apr 23, 2017 | 04:57 PM
Joe in NH's Avatar
4th Gear
Default Sway bars on a D1, 1996
I recently purchased a '96 D1 that has been lifted and modified with off road gear. It appears to have both front and rear frame mounts for sway bars but the sway bars / links have been removed, does anyone know what years will fit. Is anyone parting a D1 and have a set they would like to sell?
Thanks, Joe in NH
Old Apr 24, 2017 | 03:36 PM
jastutte's Avatar
any year from 1996 to 1998 should work. technically all the way up to half way through '99.
if you are in the north east contact Paul Grant, a member here who sells used parts. i believe that he is also in the NE.
Old Apr 26, 2017 | 12:34 AM
El Duce's Avatar
When the truck is lifted the geometry of the sway bars is changed and they bind up when the suspension is flexed, you're probably better off without them
Old Apr 26, 2017 | 03:52 AM
loanrangie's Avatar
I still have my sway bars and a 3"lift and dont notice any binding, if you want maximum articulation then leave them off.
Old Apr 26, 2017 | 11:56 AM
fishEH's Avatar
I don't know how that's possible. Those links have to be flipping amd getting stuck uo against the spring every time you flex a little.
Old Apr 26, 2017 | 05:14 PM
loanrangie's Avatar
Lift has been in for 10 years and done some pretty gnarly tracks without issues.
Old Apr 27, 2017 | 06:28 AM
WaltNYC's Avatar
laonrangie is in Australia, so like the toilets swirling in the opposite direction, the swaybars do to!
Old Apr 27, 2017 | 07:20 AM
loanrangie's Avatar
Yep that must be it, if it was binding and rubbing there would be tell tale signs and after spending a few hours replacing all the bushes on my koni shocks there are no signs at all.
deer4011
Jan 12, 2021 07:10 AM
greenwade
Apr 13, 2010 10:08 PM
oysterhead
Apr 6, 2010 11:31 PM
Speed racer
Nov 11, 2009 09:44 AM
lipadj46
Aug 25, 2009 08:39 AM
