time to order some parts..need help with list
Old Aug 26, 2010 | 08:12 PM
NiteTrain's Avatar
Default time to order some parts..need help with list
As I said in my other post I bought a well used D1 so I'm replacing the common failure parts...making a list..help me think of things I might run into that will need replacing..I'd like to order all this stuff together to save on shipping.
rear diff pinion seal
rear wheel seals left and right
U-joints for drive shafts
front axle shaft seals
front swivel ball seals
changing all fluids of course
set of wheel bearings for when I need them
what else ???
Old Aug 26, 2010 | 08:29 PM
Before you go ahead and change all the rear axle seals replace the rear axle breather.
It rusts and then clogs and then the diff cant ex spell then pressure that builds up and blows out the seals.
Replace the clogged breather and the seals stop leaking.
This is very common on DI's and that is exactly what mine was doing when I bought it.
It has not leaked since, 40k+.
You joints you can get anywhere.
As for the wheel bearings, buy the kit, it comes with everything you need.
http://www.roverparts.com/Parts/9002D.cfm
You will need 4 kits for all four wheels.
http://www.roverparts.com/Parts/FTC2176.cfm
http://www.autozone.com/autozone/par.../N-j9lziZ6o242
http://www.roverparts.com/Parts/9240.cfm
Old Aug 26, 2010 | 08:35 PM
NiteTrain's Avatar
thanks for the tips spike..anyway to clean out the rear axle breather or does it have to be replaced?
Old Aug 26, 2010 | 08:46 PM
You can remove it, and then remove the tubing and blow through it, if it is clogged go to Home Depot and buy ice maker water line, same stuff as the breather tubing.
Take the breather apart, then take a drill bit and with your hand ream it out, make sure all the holes are clear, then clean it with carb cleaner, let it dry and put it back.
You may also need to take some emery cloth to it to clean up the banjo bolt.
It is is to rusty it will need to be replaced.
I take mine apart every spring as part of my spring time maintenance and clean it up.
I will need to replace it next year though.
I used zip ties to re-string my breather tubing, leave them loose so it can move with the axle.
Old Aug 26, 2010 | 09:35 PM
lordmorpheus's Avatar
Spend the extra few $s and get the black line from the hardware store, if you want black line. Don't be cheap and get the clear line, thinking you can simply dye it black with some RIT fabric dye (because thats what you used to dye R/C car parts with, back in the day).
Sincerely,
the guy with the really pretty purple colored rear axle breather
Old Aug 26, 2010 | 09:39 PM
Sincerely,
That is the funniest thing I have heard all week.
Old Aug 27, 2010 | 07:25 PM
Danny Lee 97 Disco's Avatar
Some good tips there Spike.
Old Aug 27, 2010 | 07:57 PM
antichrist's Avatar
Skip the kit, not only are they overcharging for the bearings for your "discount" kit, it includes a crappy hub seal.
Get RTC3511 hub seals.
Get the paper flange gaskets if you want them.
Get a couple of the lock washers, they can be reused 3 or 4 times depending on how careful you are. Or 4 if you want.
The get the bearings locally for about $15 each (2 per hub).
Bearing is Timken SET37, SKF BR37, *** KIT3 or National A-37
Also skip the Duralast u-joints, they are made in China (even though they are using the Neapco part number). Occasionally people luck out and find PDQ/Neapco u-joints at Autozone, but you're safer getting them at Advance Auto, PDQ 1-0005 because they are always the real deal.
Check out Rovafarm (www.rovahfarm.com) for parts. Good prices, and they ship by USPS priority flat rate which saves money if you're getting anything small & heavy. I get the parts usually in 2 days.
Robwsup
Mar 11, 2010 10:28 PM
Billabong
Jan 27, 2010 12:36 AM
RoverRover1
Jun 1, 2009 09:37 AM
CANAMDiscovery
Apr 6, 2009 05:12 PM
mx930
Dec 30, 2008 08:08 PM
