Tire Size
Old Jan 27, 2015 | 09:47 AM
  #21
swak6287's Avatar
I like these post, and yes, thanks for the visual comparison of the tires and lift.
Old Jan 27, 2015 | 10:20 AM
  #22
USNAVYORDNANCE's Avatar
Yeah the visual really helps when building a rig. Thanks again for the reference Fish. I think I'm pretty close if not equal to the size of lift in the middle rig now that I installed the spring spacers. My rig is harder to hop into now and I'm 6'3''... Lol.
Old Jan 27, 2015 | 10:28 AM
  #23
fishEH's Avatar
Yeah I only had 3" RTE springs in there with some spring wedges under the back spring perches. Your truck looks good. You may want to toss some rubber isolators between your front spacers and the upper spring perch to reduce any harshness/chatter.
Old Jan 27, 2015 | 10:58 AM
  #24
No chatter as of yet. I did add a dab of grease to the perches for that same reason. I will do it if it does chatter in the future. They sell these things called spring boosters at O'reilly auto parts that I can throw in without having to remove it all again.
Old Jan 27, 2015 | 10:45 PM
  #25
CUpgt's Avatar
315/75s are awesome but it's a very expensive commitment! If you ever go down that road get accustomed to sheet metal removal...
Old Jan 27, 2015 | 11:59 PM
  #26
Haha, nope... Went with 285/75's. Others can take note of that tho.
Old Jan 28, 2015 | 12:32 AM
  #27
CUpgt's Avatar
I ran 285s on a 2" lift and for a while with my 3" RTE springs. They are a good tire size as well, I just wanted 35s because all my wheeling buddies are on 37s or 40s with buggies or truggies and I had the drivetrain to hold them.
Old Jul 16, 2015 | 09:40 PM
  #28
Markster's Avatar
I'm running a 3" OME lift and i found a 245/75/16 is the biggest tire i can run with full articulation without cutting fenders.
Old Jul 16, 2015 | 10:12 PM
  #29
fishEH's Avatar
What's the point of 3" of lift to run 245/75's? You could probably fit those with 1" of lift or maybe even stock.
Search the Camel Cut. You trim a very little bit off the back or the front and rear fenders to clear the tires. You can make it look good where you wouldn't be able to tell by glancing at the truck.
With 3" of lift you should have no problems with 235/85 or even 255/85 with very little trimming.
Old Jul 17, 2015 | 05:53 AM
  #30
MM3846's Avatar
He must be another one of those never cut, never extend bump stops people.
stock, 245/75-16, no rubbing. just had to do a camel cut.
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
samsly
Tires
Feb 27, 2006 07:01 AM
chefman
Jan 18, 2006 10:15 AM
jhstew1
Jun 14, 2005 03:41 PM
