took out the Y pipe
Old Dec 24, 2012 | 10:02 PM
Shawn Cross's Avatar
Default took out the Y pipe
On my 96 SE7 if i drop the Y pipe down shouldnt i get rpm. It won't go more than 2000rpm. There is no difference with it on or off. I thought there would be some kind of change. Anyone have any ideas?? thanks
Old Dec 24, 2012 | 11:22 PM
Jake1996D1's Avatar
crank shaft position sensor
Old Dec 25, 2012 | 06:00 AM
Any codes, have you checked your fuel pressure?
Old Dec 25, 2012 | 06:49 AM
ihscouts's Avatar
Not to undercut ya Jake, seriously. I'll toss out my guess as the Throttle Position Sensor. If it fails in the closed position it cuts fuel above 1750 rpm. Just another sensor to check on. Anybody who'd drop the "Y" pipe to check Cat restriction deserves a couple of options.....
Old Dec 25, 2012 | 10:07 PM
You can watch the TPS live on a live data OBDII scanner, if its dead the values on the scanner for the TPS will not change with your foot on the go pedal.
Eaglerover22
Feb 21, 2012 04:02 PM
sleepercoupe
Apr 17, 2011 02:03 PM
malmberg
Oct 27, 2009 12:12 PM
VikingDiesel
Mar 13, 2009 08:11 PM
Benhamtroll
Apr 20, 2005 05:46 PM
