Tranny Problem.
Old Feb 21, 2013 | 11:36 AM
Ron6977's Avatar
Default Tranny Problem.
Oh.... Wait..... What!!!! Not that type of Tranny......A Transmission issue.
The first time i take my truck out for the day, It does not want to shift out of first gear for a very long time. I have to go about 2-3 miles before it finally shifts, then its fine for the rest of the day.
The fluid looks and smells clean. Doesnt taste to bad either.
Thanks
Old Feb 21, 2013 | 12:34 PM
koolkoreanked's Avatar
Take the vehicle out and try shifting manually to see if it shifts. Sounds almost like a valve body issue.
Old Feb 21, 2013 | 12:49 PM
Ron6977's Avatar
Sorry guess i should have added that. Tried it, no difference.
Old Feb 21, 2013 | 07:08 PM
Valve body issue, you need to have it flushed.
If that does not do it you need it rebuilt, or at least replace the valve body with a good working one.
Old Feb 22, 2013 | 07:26 AM
Higgs Boson's Avatar
The governor has metal in it or the Viton rings are hard. The ZF units tend to collect any stray particles in the governor. When the Viton rings start to get hard they don't seal until the unit starts to warm up a bit and the warm fluid softens them and makes them pliable. Generally the metal comes from the A clutch being worn.
You MAY be able to save it (at least for a while) by pulling the transfer case out, removing the adapter housing, removing the governor support, and cleaning the governor and governor valves and replacing the Viton rings. The governor support actually rides on the overdrive drum, where the rings are located. You will also want to pull the pan and replace the filter and spray out the gray gunk coating the valve body. The best way to clean the governor is to disassemble it and use fine crocus cloth to polish the valves and the aluminum housing bores where the valves ride.
Put it all back together, fill it up, and cross your fingers.
Old Feb 22, 2013 | 12:02 PM
Ron6977's Avatar
UGH!!!!! I should have finished my first cup of coffee before reading this.
Im going to have to try flushing first and cross my fingers. I hate tranny work, Ive been forced to do it in my old Chevy's and Dodges before back in the day.
But im developing a real love hate relationship with my Disco.
Thanks for the help guys, will have to see what happens.
Old Feb 22, 2013 | 12:29 PM
A note of caution, the ZF is more complex than the old Detroit iron. For a master like Higgs it is everyday, for us mere mortals not so much. Many Rovers are in boneyards because of overheat and engine problems, so a used tranny could also be an option.
idahorover
Oct 28, 2010 08:12 AM
gardens1999
Dec 19, 2008 10:50 PM
Chillbred
May 5, 2008 07:27 PM
sm3earl
Feb 15, 2007 12:26 PM
dragon
Nov 3, 2006 10:50 AM
