Transmission light doesn't turn off.
Old Jan 11, 2011 | 02:27 AM
christaci's Avatar
5th Gear
Default Transmission light doesn't turn off.
Disco 1997 petrol. My tranny light has come on for no reason. I had the tranny box serviced but it still won't turn off. Any suggestions would be greatly appreciated. Chris
Old Jan 11, 2011 | 09:47 AM
You have a bad temp switch.
Old Jan 11, 2011 | 11:12 AM
Spencerfitch's Avatar
Bad or dirty transmission temperature switch. One is located on transmission fluid cooing line at the radiator. The other is on transfer case.
Old Jan 11, 2011 | 04:08 PM
christaci's Avatar
5th Gear
Thank you. I am not very mechanical minded. Is the remedy something I can attempt myself or should I take it to a mechanic.
Old Jan 11, 2011 | 04:17 PM
Something you can do easily
Old Jan 14, 2011 | 12:01 AM
christaci's Avatar
5th Gear
Default Plug lead diagram
Hey Mike, thank you for your previous advise. I changed the temp switch and the light is off. Would you by any chance have a lead plug diagram to send me. If so I appreciate it and I thank you in advance. Chris
Street Wolf
Oct 10, 2023 08:11 PM
Tricked306
Dec 6, 2018 11:37 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
elanghout
Sep 23, 2006 10:42 AM
mrmozambique
Aug 23, 2006 03:34 PM
