Driver door handle, key cylinder doesn't turn
Old Jul 19, 2011 | 01:22 PM
Tricked306's Avatar
5th Gear
Unhappy Driver door handle, key cylinder doesn't turn
Hello All. Well after taking a brick to the window last night, I was finally able to get in the truck (2001 D2). Had no other choice, 2 locksmiths tired, but had no luck. Apart from acouple of actuators going bad, neither the alarm nor the key hole worked . Good news is the truck starts and is drivable, but not able to lock.
* Here is my problem.....the driver door (central lock) key hole, doesn't turn either left or right when I put in the key. When I insert the key, it is stuck in position. I have tired even applying some force, but was afraid to break the key in there. What are my options ?? Some guy down here said he would charge like $650.00 to change the whole keys, locks, programming, etc.... I know there has to be a cheaper way. Even if I have the carry around a different key for the door, I am ok with that.
Can this lock be fixed on a junkyard budget ? I still am going to remove the handle tonight to see exactly what the damage is.
Any help, would be greatly appreciated
Thanks,
Leo
Old Dec 6, 2018 | 10:11 AM
Cary Lynn Robertson's Avatar
Default Key wont turn
Did you ever get this issue resolved? I am having the same problem.
Thanks,
Leo
Old Dec 6, 2018 | 11:18 AM
abran's Avatar
Need to remove the handle to troubleshoot. Where are you located? If near so cal, I can help.
Old Dec 6, 2018 | 11:37 AM
mln01's Avatar
Cary, welcome to the forum! I see this was your first post.
I had this problem a year and a half ago. My forum thread with pictures detailing the problem and the solution (in the case of my truck) is linked below.
gilberjm
Aug 6, 2019 11:51 PM
Kadin Wallner
Sep 27, 2018 10:01 PM
alohadaniel73
Jun 26, 2018 12:17 PM
Beca7303
Apr 27, 2017 12:39 AM
Hawkins3231
Apr 24, 2016 03:44 AM
