Transmission Service
Old Mar 19, 2014 | 10:52 AM
spikeRovah's Avatar
Default Transmission Service
Hello all,
Just got a new engine (from Atlantic British) and have yet to install it (planning on it this weekend).
My truck is 97 Disco with 158K on transmission.
I was hoping I can get some high mileage service advice. I was told every 60K to service the trans, but I bought the truck at 151K, and I have no idea if the previous owner serviced the trans at all.
I don't wanna open a can of worms.
I haven't had any issues with the trans since i owned the truck. It clunks into reverse every so often, but otherwise nothing peculiar.
So yeah, any help would be greatly appreciated.
Old Mar 19, 2014 | 11:01 AM
drowssap's Avatar
get your motor in and everything worked out, then in a few weeks you can decide if you want to chance changing the fluid and filter.
Old Mar 19, 2014 | 12:02 PM
spikeRovah's Avatar
That's definitely the plan!
Thanks.
Old Mar 19, 2014 | 04:17 PM
claudio413's Avatar
Just change the oil in the differentials, almost easy, if they were neglected the transmission prolly is too.
I just changed mine, and left the filter alone, just two fluid swaps of about 5 quarts each, and now my 98 shifts like butter. Like butter.
Old Mar 26, 2014 | 10:36 AM
spikeRovah's Avatar
That sounds heavenly. Thanks for the advice!
Old Mar 26, 2014 | 01:00 PM
AK_Disco_Driver's Avatar
You must love your disco to spend 6k on a motor plus the core charge. You probably could have had your block redone and built a new motor for less but I bet it's shiny! Double check your valve timing and adjustments before you put it back in.
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
starcraft
Mar 4, 2008 03:14 PM
tailchaser0527
Jan 16, 2008 09:36 PM
JKK
Oct 13, 2005 10:49 PM
