turn the key on and hear ticking.
Old Oct 18, 2013 | 04:25 PM
jimvw57's Avatar
Default turn the key on and hear ticking.
Was doing some cleaning up and I must have soaked something, Turning the key to the on position I was hearing a click (just one) now it sounds like a ticking sound or fas clicking and back to no fuel pressure. I cleaned the connectors on the relay under the hood as I found that when I loose fuel pump pressure and play with that relay (pair) it seemed to help. now I got something new...
Old Oct 18, 2013 | 11:52 PM
CUpgt's Avatar
Sounds like a starter. Let it dry out good.
Old Oct 19, 2013 | 12:26 AM
nuclearw's Avatar
eh check batt voltage too.. just incase
Old Oct 19, 2013 | 08:25 AM
jimvw57's Avatar
engine turns ove fine. I think I have cleaner fluid (from contact cleaner spray) inside the MFU and it is causing the circuits to go on and off quickly. Took the relay apart and dried it out and cleaned some corrosion from between the plug in pins on the smaller connector. Batt voltage is good. Same with starter.
Old Oct 19, 2013 | 11:31 AM
jimvw57's Avatar
Installed the cleaned MFU, started right up and purrs like a Land Rover..
Correction: I cleaned out the relay unit in the engine compartment. I drove about 5 miles, shut it off and now it doesn't start again. Thinking I may have soaked water into the Engine Control Module, located in the right rear corner behind the washer bottle. Gonna pull the washer bottle and see what I can see.
Old Oct 20, 2013 | 03:02 PM
jimvw57's Avatar
Took the center console apart and fond out I do not have a spyder unit in my vehicle.
Old Oct 20, 2013 | 03:31 PM
jimvw57's Avatar
Pulled the GEMS module and found corrosion on the bottom edge, and inside on the case. May have been messing up a ground as the spots for the screws on the circuit board also showed signs of white powdery corrosion.
I assume this should be sealed from the elements.
Humdinger
Oct 18, 2016 05:05 PM
john65b
Oct 10, 2013 05:00 PM
Disco2001
Sep 20, 2011 11:11 AM
Aquaholic
May 1, 2007 12:18 PM
