Turn signal/flasher issue
Old 10-09-2013 | 10:16 PM
abran's Avatar
Default Turn signal/flasher issue
Hi all,
When I activate my turn signal(either direction) the trailer icon and the arrow flash on the dash.
Outside(either direction bring activated) both right and left side blinkers go on like I have my hazards on.
Anybody know what's going on?
Thanks
Old 10-09-2013 | 10:28 PM
coors's Avatar
I think you may have a bulb out or a loose connection at one of the terminals. Check all bulbs to make sure there good and tight. Then, check all wired connections to the bulb.
I had a similar issue turns out I had a loose connection.
Old 10-09-2013 | 10:43 PM
abran's Avatar
Thanks coors! I will check tomorrow.
Old 10-09-2013 | 11:18 PM
scottmb23's Avatar
What Coors said. I have this issue right now and its due to a corroded wire harness on the rear-right bumper signal, $13 replacement being picked up tomorrow to solve my issue.
Old 10-10-2013 | 10:00 PM
abran's Avatar
So, there was an aftermarket tow wiring harness with a central box that was tied into the rear lights. I removed it and the problem was solved!!!
Thanks for the clues.
xrundelek
01-11-2011 09:32 PM
85Red110
Defender
11-19-2010 04:51 PM
AnnelieseMae
02-24-2009 01:14 PM
D2000
06-08-2007 12:12 PM
billinohio
03-14-2007 12:43 PM
