Ultragauge EM
Old Jun 8, 2012 | 02:45 PM
  #51
oilspotLR's Avatar
Thank you ToddD!
Can't wait to play around with it.
Old Jun 8, 2012 | 02:50 PM
  #52
EricTyrrell's Avatar
Originally Posted by Spike555
You can adjust how fast the UG updates itself, I have mine set at the default setting which I think is 15sec, in the mean time it estimates the readings.
You can tell when it updates because it will go blank for half a second and then show new info.
Mine updates every second and only goes blank when switching pages. I might have configured it that way though.
Old Jun 8, 2012 | 07:36 PM
  #53
Originally Posted by oilspotlr
thank you toddd!
get a room guys!!!
Old Jun 8, 2012 | 07:37 PM
  #54
I went with the default setting, I might change it, I dont scroll pages.
Old Jun 8, 2012 | 09:24 PM
  #55
oilspotLR's Avatar
get a room guys!!!
Oh spike!!! Anyways I got the Ultra Gauge today in the mail. I now have to wait until I get my new toy.... The Discovery II. My DI isn't compatible.
Old Jun 16, 2012 | 12:44 AM
  #56
oilspotLR's Avatar
With the ultra gauge I am running 194-199 in town with no a/c on. With a/c in town I saw it start climbing and I turned the a/c off at 210 and maxed the heat. **
It was in 100 degree temps but this is no excuse.**
I just replaced the thermostat for the one that opens 10 degrees lower than stock and these were the readings.
I might not of gotten all the air bubbles out of it. I did notice that I was low on coolant because I didn't refill it all the way after I replaced the thermo.
I took the fan cover off that goes around the radiator and found that the radiator has "gunk" looks like dog hair to be exact covering it. So does the A/C condenser. I will clean the rest of that tomorrow with the air compressor.
Old Jun 26, 2012 | 08:48 PM
  #57
macro1's Avatar
Ultragauge is awesome.
Mine is running about the same with a 180 thermo, brand new GM fan clutch, except I run about 199-203 with ac. I seem to get above 210 when there is a lot of load on the motor. I peaked 220 while traveling through the mountains with a fully loaded truck.
Curious to see if flushing the system will make a difference for you.
Old Jun 27, 2012 | 10:30 AM
  #58
ToddD's Avatar
Flushing helped. The fluid was an unknown age, at least 1.5 years, so I'm sure it made a difference. I've seen a reduction in temps. Still will reach up to 215 uphill, middle of the day, a/c on.
Our numbers look very similar. I put in a 195 t stat, that's all they had at the store and I was in a rush.
'BamaBoy
Feb 20, 2014 04:39 PM
dcarr1971
Sep 19, 2012 09:08 AM
anbran
Sep 14, 2012 10:07 AM
Antmen
Sep 12, 2012 11:11 AM
slanginsanjuan
Mar 9, 2012 03:55 PM
