V8 Thermostat Installation Direction?
Old Mar 16, 2014 | 09:10 PM
Algernon's Avatar
Default V8 Thermostat Installation Direction?
As I view this image of the coolant flow for the V8i engine from the RAVE manual:
It's not crystal-clear exactly which side of the thermostat fits into the block. I've always heard SPRING-SIDE into the block, but after examining my WAHLER (German) thermostat, (and THE coolant flow direction EXITING the block at the housing that feeds the upper radiator hose) it sure seems like the SPRING-SIDE should be out for optimal operation of the thermo-valve. And the spring side DOES fit into the (top) radiator hose housing. Worse - the close up drawing in the same manual gives no better indication of this "polarity":
The Wahler thermostat in question: (Wahler #W0133-1636663 (88 C)
Any thermostat polarity insights specific to the V8i engine in this 1995 Discovery I ???? (SPRING: IN or OUT for the V8i?)
thanks!
Bob Peterson
Portola Valley, California
Algernon, 5-speed (now rare!) 1995 Discovery
Old Mar 16, 2014 | 09:29 PM
XCELLER8's Avatar
Thumbs up
spring in on mine....
Old Mar 16, 2014 | 09:34 PM
TOM R's Avatar
Spring faces in cause the heat probe it that side, engine heat causes spring to compress opening the valve, there should be a weep hole in the lip of the stat, it goes at 12 o'clock to bleed air from the system
Old Mar 18, 2014 | 11:50 AM
Algernon's Avatar
Thanks! In 122K miles, I've changed the thermostat TWICE and never questioned "spring-in." I'll stick with what works then.
Bob
Old Mar 18, 2014 | 09:07 PM
XCELLER8's Avatar
I'd like to add that i have purchased thermostats before that came with no "weep" hole as Tom mentioned above.....it's a good idea to drill one if there isnt one...its easier to bleed the system
Old Mar 19, 2014 | 03:45 AM
X2 on all above - and if your just purchased Rover has no stat, most likely that is because of overheating. Will run without a stat, my D1 would make about 145F. Needs a working stat. I prefer the 180F models.
Old Mar 19, 2014 | 04:52 AM
antichrist's Avatar
Here's a good one with a jiggle pin https://landroverforums.com/forum/di...rmostat-51327/
Old Mar 19, 2014 | 08:07 AM
TOM R's Avatar
Do not use the fail safe ones mine killed it
Resendiz
Sep 9, 2012 01:59 PM
ryans97discovery
May 5, 2011 08:22 AM
calebmorphew
Jan 20, 2009 10:14 PM
bcolins
Oct 11, 2008 08:23 PM
kraelo
Apr 1, 2008 12:02 AM
