Valve cover on a 98 D1 4.0
I'm getting ready to replace the valve cover gaskets on my new 98 Discovery with a 4.0. Other than the valve cover gaskets are there any other parts I will need for the job? I see the intake will probably need to come off.
Also looking for any advise on anything else to look for when I have it apart. I just picked this beauty up.
it may be easier for you to remove the intake plenum ( which will allow you to clean it better anyway ) and beware of the little metal bushings that go in the bolt holes on the new gaskets......they like to fall out of the gasket as you are positioning everything....and god help you if it falls inside the motor.........
[QUOTE=XCELLER8;578125]it may be easier for you to remove the intake plenum ( which will allow you to clean it better anyway ) and beware of the little metal bushings that go in the bolt holes on the new gaskets......they like to fall out of the gasket as you are positioning everything....and god help you if it falls inside the motor.........[/QUOTE
thanks for the tip. Is there's gasket on the plenum?
austinlandroverbill
Apr 1, 2015 06:26 PM
wease206
Mar 1, 2007 07:38 PM
