remote
Old Jul 28, 2016 | 09:16 PM
aemnky606's Avatar
Default remote
My local junk yard has a 1996 disco I and it has a remote. I know I need to program it to my truck, but if I pull the Green alarm box from the truck with the remote will it work. or do I need some other things?
Old Jul 28, 2016 | 09:37 PM
RedRovin''s Avatar
Alarm control module is paired with the Engine Control Module under the hood. If you take one, you have to take the other
Old Aug 14, 2016 | 09:04 PM
aemnky606's Avatar
that's what I was afraid of. I went back to pull the ECM and it had a huge hole in the bottom back and massive corrosion on the boards so I guess I will have to wait till I get a better scanner/programmer.
Old Aug 16, 2016 | 08:26 AM
ihscouts's Avatar
How much did they want for it? I'd snag it if it's cheap and try it. They're not always paired....
Old Aug 16, 2016 | 03:22 PM
aemnky606's Avatar
It was $35 for both alarm control module and the ECM so I will see if it works.
Old Aug 16, 2016 | 03:59 PM
ihscouts's Avatar
See how bad the ECM circuit board really is. If it's just surface corrosion it's not a big deal to clean it up.
Old Aug 24, 2016 | 07:10 PM
aemnky606's Avatar
well the ECM is toast. looks like water got in it and shorted out. Finally got some time to look it over.
Old Aug 27, 2016 | 12:47 PM
SocalD1's Avatar
I changed out the Green 10AS box with another from a newer truck 98, and it worked with no problems. Give it a try!
RROJ
Oct 9, 2010 07:39 AM
RROJ
Oct 8, 2010 09:56 PM
oberdahill
Nov 26, 2005 01:53 AM
Jay
Apr 27, 2005 03:49 PM
