Vehicle Speed Sensor question
Old Jan 25, 2017 | 09:58 AM
Four_Stroke's Avatar
Default Vehicle Speed Sensor question
Hi Guys,
I am in the process of replacing my VSS and the replacement part seems to be loose. The center part of the sensor (where the square shaft comes out) is fairly loose. It won't come out but it does wiggle around. Is this normal? I ask because the part came from the UK, new but had no packaging to protect it.
Old Jan 25, 2017 | 01:46 PM
WaltNYC's Avatar
yes, normal. but still crappy.
Old Jan 25, 2017 | 02:36 PM
Thanks for the response Walt.
I just found the 'rebuild VSS' doc as well. I'll rebuild my old one and have a spare.
Old Jan 25, 2017 | 06:23 PM
WaltNYC's Avatar
Let me know if you find a good adhesive to hold the magnet on the shaft.
Old Feb 12, 2017 | 06:53 PM
Sorry for such a delayed response. I haven't been driving the Rover so it hasn't been a top priority. I rebuilt the VSS and boy was it a POS unit off of ebay! I used a large nylon fender washer trimmed down and drilled the center out to form the bushing for the magnet shaft on the inside of the sensor. The sensor I bought from ebay had the magnet attached to the shaft via a small clip and a washer as a spacer, so I replaced the washer with the nylon fender washer above. Loaded the entire unit with lithium grease and rtv'ed the sensor together. it now works, I get mph readout on my OBD 2 scan tool. Now my speedo doesn't work, odometer works. So i'll tear into that this week and see if a solder joint is broken.
tcbinaflash
Nov 27, 2018 06:32 PM
4Low
Jul 15, 2014 06:48 PM
vorticistssuite
Nov 23, 2013 03:20 PM
grussell
Oct 6, 2009 08:14 PM
ajordan_0012000
Feb 20, 2009 02:19 PM
