War on Misfires
Old Feb 23, 2012 | 09:13 PM
  #71
XCELLER8's Avatar
[QUOTE=
Have you looked at the inside of your ECU yet? I am just wondering if there is aproblem internal to the ECU.[/QUOTE]
2x on that ( that was my issue 2 weeks ago )
Old Feb 23, 2012 | 09:20 PM
  #72
Danny Lee 97 Disco's Avatar
Yeah, the inside of the ECU may be all corroded up giving you erratic behavior as well. Since you didn't get much driving time when you first bought it, you may be dealing with a pre-existing condition instead of something you did wrong. i would look at that prior to tearing down the newly assembled motor.
Rule out any simple possible causes first.
Old Feb 24, 2012 | 10:47 AM
  #73
EricTyrrell's Avatar
My ECU looks brand new inside and out. It's really spotless and sealed too.
I'm guessing CKP will be here tomorrow to test.
I'll check knock sensors just in case too.
Old Feb 24, 2012 | 11:51 AM
  #74
ValveCoverGasket's Avatar
it uses one edge as the trigger, not the center of the waveform.
thats unusual, all other VR sensor circuits im familiar with use 0 crossing as the trigger point. the peaks of the waves are not always uniform
Old Feb 24, 2012 | 02:46 PM
  #75
Attached data sheet on CKP from Bosch manual for a D2, should be similar (sensor, plate, different ECU). Uses term "falling edge".
File Type: pdf
Old Feb 24, 2012 | 03:06 PM
  #76
So it is a Square Wave Form, It has been many years since I have even seen a scope, much less had to set one up and use it.
Old Feb 24, 2012 | 03:36 PM
  #77
no, its not, its just showing you the shape of the trigger wheel teeth. the trace will look like the one on the right side of the picture i posted earlier.
it sounds like it uses the zero crossing on the vertical part of the "backside" of the wave, rather than the "flat" spots. in any case, it doesnt use the peaks - ive never heard of a VR circuit that does
Old Feb 24, 2012 | 05:01 PM
  #78
falling edge, as compared to "center of wave". Because of that, reversed polarity will put you on the opposite edge, 3 degrees off.
Old Feb 24, 2012 | 08:08 PM
  #79
If I may ask, is P1316 related? I popped that twice here lately.
Old Feb 24, 2012 | 08:12 PM
  #80
Time for Seafoam or witch's brew of choice and new plugs - does not relate to just cylinder #6
