Water puddle = sputtering
Old Aug 21, 2016 | 08:18 PM
dsmeddy's Avatar
Default Water puddle = sputtering
So..... I ran through a Water puddle today which shot water in many directions. Once I got through it, the Disco started sputtering and not wanting to do anything above idle rpms 700ish. I pulled over and lifted the hood and found the entire top of the engine completely dry. I put the vehicle in park and it idled just fine. When I gave it some throttle it just kept sputtering. 10 minutes go by and eventually all things went back to normal. I imagine something dried out within that time.
My question is.... What wire connection or what could've gotten wet (probably on lower 1/2 of engine) that would of caused this? All top part of engine was dry.
Many thanks
Old Aug 21, 2016 | 09:01 PM
fishEH's Avatar
Did you check your airbox/MAF?
Old Aug 21, 2016 | 09:09 PM
dsmeddy's Avatar
Air filter intake was dry and all hoses dry on top of engine as well as the ignition coils dry.
97' D1
Old Aug 21, 2016 | 10:56 PM
XCELLER8's Avatar
two things come to mind....the crankshaft position sensor ( or the cracked wiring to it) drivers side lower rear of the block, and also the fender mounted ECU....strategicly located over a rust hole on the passenger side front fender, it may be wet inside ....you can remove it and have a look...then seal it back up
Old Aug 22, 2016 | 10:36 PM
dsmeddy's Avatar
What is this dangling? The crank sensor connection??
Old Aug 23, 2016 | 10:11 PM
XCELLER8's Avatar
the wire connector to the crankshaft position sensor plugs directly into the sensor, its on the lower part of the engine block, at the rear of the engine ( where the flywheel is) and usually has a tin heat shield ( bwhahahhaa ) covering it....the wires to it get heat baked and the insulation crumbles off allowing water to short it out .... google the sensor for a pic of it
this looks more like an O2 sensor connection ?
bcbp
Aug 31, 2016 07:37 AM
slskier88
Apr 29, 2014 04:14 PM
Adam78
Mar 18, 2013 03:04 AM
bikeG976
Nov 14, 2009 03:53 PM
deepessions
Mar 24, 2007 10:32 AM
