Water Pump Help
Old Oct 1, 2010 | 05:59 PM
Spencerfitch's Avatar
Default Water Pump Help
Its time for a new water pump, leak + costant sqeek.
Are they all the same? Certain brands I should look for?
I have never done a water pump, I hope its not too difficult.
Old Oct 1, 2010 | 06:28 PM
discomedic4's Avatar
I ordered my water pump from RovahFarm. He got me the right pump at one of the cheapest prices I could find at the time. I don't actually think there is anything wrong with the one I pulled I was just moving through the various parts of the cooling system trying to clear up my overheat problem. It looked fairly new when I pulled it. Anyway try Trevor over there at RovahFarm. As for the replace it is pretty simple. Take a look at the RAVE as you already know. With all the work you did replacing the gaskets and cleaning up your engine you won't have a problem with this one. It took me maybe an hour and I was doing several other things at the same time. The most time consuming part for me was getting the old gasket off. That was liking chiseling concrete. Good luck spence.
Old Oct 1, 2010 | 08:50 PM
XCELLER8's Avatar
2x on Trevor @ the Rovahfarm......he's saved me a ton of $$$
Old Oct 1, 2010 | 09:31 PM
kenk's Avatar
x3 for rovahfarm. I did mine 3-4 months ago, I thought easy. Remove shroud, remove fan and clutch,remove belt and tensioner pully. A bunch of bolts on the pump itself and its off
Old Oct 1, 2010 | 09:32 PM
soo I should get the allparts or the original one from their web site?
Old Oct 1, 2010 | 10:14 PM
I am about 98% sure I went with the all parts. Seemed like solid construction and no problems out of it.
Old Oct 2, 2010 | 12:41 AM
kenk's Avatar
I went with the cheap one, no prob's
A5scott
May 18, 2015 06:34 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
mooal5
Feb 17, 2008 09:01 AM
SH8KDWN
Jan 15, 2006 06:45 PM
mke137
May 15, 2005 02:54 PM
