water pump question
Old Jun 3, 2011 | 01:10 PM
disco_fever503's Avatar
6th Gear
Default water pump question
Anyone here currently use or have past experience with a duralast water pump from Autozone? I need one ASAP and this is my fastest option
Old Jun 3, 2011 | 02:04 PM
kamileon's Avatar
I havent had the dis-pleasure of replacing mine yet, but with autozone you do get a warranty, so if it is bad or goes bad you can take it back.
Old Jun 3, 2011 | 02:07 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Works fine.
Old Jun 3, 2011 | 03:30 PM
6th Gear
I was able to locate a new factory pump for $100, compared to the $190 pump at autozone. Thanks for the input guys
Old Jun 3, 2011 | 03:38 PM
6th Gear
What are some thoughts on factory pumps? most of the dealers I speak to try to steer me away from the factory
Old Jun 3, 2011 | 06:19 PM
LRD2&ME's Avatar
As long as the propeller shaft and propeller are not plastic, everything should be fine. My late BMW had a plastic propeller attached to a steel shaft. Bad combination. I was doing a donut on dry pavement one day and poof. The radiator split, the waterpump propeller disconnected from the shaft. Safe to say I'll never own another piece of S*** BMW again. The one component that really makes the difference is the bearing. However it is near impossible to determine a good bearing from a lesser quality by visual only. A bad pump will make noise. This is the bearing. Either rusted out or started to sieze up. As long as the propeller still spins, the propeller still draws in coolant.
A5scott
May 18, 2015 06:34 AM
Travelor
Dec 29, 2011 03:39 PM
Savannah Buzz
Jul 21, 2011 08:02 PM
nickd503
May 13, 2009 06:59 PM
Jawbox
Mar 10, 2009 07:29 PM
