Water Vapor From Tail Pipe.
Thanks guys for all the help. I now know i have it in backwards. I hope that is the cause of my vapor out the pipe. Gonna have to wait till tomorrow to to fix it. hope that will do it. Night night meds are kickin in, and if im not in bed when they really hit....Thats where ill end up sleeping.
Spring goes in this hole. Any jiggle device or burp valve goes at 12:00 position. Be sure to purge air out of cooling system. If you have been running this way for a while the white vapor could be head gasket. Be sure to monitor coolant use for a while, plus don't trust the heat gauge, get a scanner or Ultra Gauge.
DITTO ON WHAT SPIKE SAID running the engine with the milky oil will kill the cam and crank bearings it will need to be towed to a shop and made clear to the tow truck and shop DO NOT START THE ENGINE BLOWN HEAD GASKET AND NO COOLANT
btw I would drain the coolant, leave it drained and put in fresh oil
I would say leave off the overflow cap with coolant but you do not know how bad it is blown( with the cap off or realy loose no pressure to blow water into the engine)
MarkJN110
08-24-2011 08:48 PM
