weird electrical problem
Old Mar 4, 2012 | 11:19 AM
smoker's Avatar
I see there are different crank pos sensors listed for auto or manual trans... can anyone confirm that they're actually different?? I found one on Craigslist locally but it's for an auto. I was about to order the one from rockauto, but if I could get one today I'd be one happy dude.
Old Mar 4, 2012 | 01:48 PM
What is different is the spacer depth. You can get a new one from Rock Auto for like $30.
Old Mar 4, 2012 | 01:52 PM
EricTyrrell's Avatar
Just use your existing spacer with whatever CKP you get.
Old Mar 4, 2012 | 02:07 PM
That should do it.
The correct air gap between the tip of the CKP sensor and the passing teeth of the reluctor ring can
be set by the correct fitting of a spacer as follows:
9.2 mm spacer for vehicles with manual gearbox fitted.
18 mm spacer for vehicles with automatic gearbox fitted
Old Mar 4, 2012 | 03:34 PM
smoker's Avatar
Ok, so on the rockauto website I see a ckp sensor for auto listed for $30 and one for a manual listed for $90. You're saying I can just buy the less expensive one and reuse my spacers?
Old Mar 5, 2012 | 02:41 PM
Chris-bob's Avatar
Waiting for a reply on this as well....I'm always looking for more affordable sensors to change out.
Old Mar 7, 2012 | 06:33 PM
smoker's Avatar
Does anyone have a definite answer on this?
Old Mar 7, 2012 | 09:08 PM
It does not come with a spacer at all. I have an auto so I just reused the spacer. It's just a piece of metal. I assume you could just use your manual spacer. Don't quote me though
Old Mar 8, 2012 | 01:54 AM
Chris-bob's Avatar
Too late...
Good info. I'll have to try it once the wife lets loose of the purse strings again...
Old Mar 8, 2012 | 07:23 AM
smoker's Avatar
Alright, I'll be the guinea pig. Ordering it today.
thehun
Jun 7, 2012 12:38 PM
rphotographer
Mar 21, 2011 09:37 AM
c_sautter
Jan 9, 2011 03:29 PM
doerhoff013
Jan 15, 2009 12:09 AM
djkiddanger
Apr 8, 2008 05:21 PM
