Weird problem
Old May 27, 2016 | 10:11 PM
KB11707's Avatar
Default Weird problem
OK, so I have a pretty weird problem with my 96 d1 that I can not find any answers to. When I press the brake pedal my radio shuts off and my rear wiper will run. With the brake pedal depressed it will not come out of park either. Thank you for your help I really need this truck to run as it is my Daily driver.
Old May 28, 2016 | 01:52 PM
stillruns's Avatar
Just came to say good luck with that.
Old May 28, 2016 | 05:23 PM
TOM R's Avatar
Bad grounds or short my .02
There's grounds back by tail lites inside, and under dash, something bad or loose
Old May 28, 2016 | 07:43 PM
BritishautoworksSD's Avatar
How long has it been like this? Did you do any work to your D1 recently?
Old May 28, 2016 | 11:56 PM
KB11707's Avatar
The problem only began a couple of days ago, and I have done work with my d1 but nothing electrical recently. I will definitely check the grounds
Old May 29, 2016 | 05:58 PM
TOM R's Avatar
Cleaning the battery ground cable at all connections and adding a ground from batt to engine and batt to rad support fixed a lot of my issues
Old May 29, 2016 | 06:17 PM
jimvw57's Avatar
sounds like a ground issue behind the rear side tail lights, or in the rear doo. maybe the 3rd brake light wiring or connector since it affects the rear wiper and radio. Antennas are back there..
Atlrover89
Jan 11, 2016 06:55 AM
ConradLeo
Jun 22, 2013 09:02 AM
pat3d
15
Apr 25, 2008 01:32 PM
alpinab7
Sep 29, 2006 03:11 AM
carpe diem
Sep 1, 2006 04:45 AM
