Weird shifting. Beginning of the end?
Old Jan 6, 2021 | 04:43 PM
  #21
hrhoward's Avatar
Groovy.
What "phone" do you use?
Old Jan 6, 2021 | 04:46 PM
  #22
leecatd8209's Avatar
Originally Posted by hrhoward
Groovy.
It's an old Huawei Honor 6x. I'm sure the Chinese are really getting a kick out of my struggles.
Old Jan 6, 2021 | 04:59 PM
  #23
Best4x4's Avatar
I had a D1 with a crazy idle and the ECU itself was corroded badly. Only way the D1 would run was if the VSS was unplugged, and the A/C was on. Removed the ECU and found it badly corroded. Grabbed another unit from LKQ, then I found the IAC wouldn't ever move, replaced it with a unit from a Jeep, reset the adaptive settings via the Lynx and I adjusted the TB (under the cap a bit to make it perfect) idles like a champ now.
Old Jan 6, 2021 | 05:02 PM
  #24
Does changing the ECU not mess up the immobilizer settings?
I don't want to open mine up without a spare on hand, ebay has quite a few for what seems to be a reasonable price.
Old Jan 6, 2021 | 06:07 PM
  #25
WaltNYC's Avatar
Check the ECU for corrosion and don't forget about the battery/alternator.
Old Jan 6, 2021 | 06:47 PM
  #26
Best4x4's Avatar
ECU wise you should be able to swap the ECU without messing up the 10AS unit. 97-99 AEL ECU's are much more common vs non AEL ECU's. I have 3 ECU's for my 97 and I can switch em around without any issues.
Old Jan 7, 2021 | 12:57 PM
  #27
New IAC installed and now I have a rock solid ~800rpm idle with good AC compensation characteristics.
I can live with that.
Thank you for all the help!
EdLR3
Aug 11, 2020 10:07 PM
cameron.french92
Aug 5, 2019 01:52 PM
DiscoRabbit
Feb 1, 2018 12:14 AM
s10lowrider1994
Jun 14, 2014 06:51 AM
SDinDS
Mar 7, 2009 11:38 AM
