Weird vibration- help!
So yesterday I noticed a very weird vibration when driving my D1. It doesn't do it, to my knowledge, when I accelerate. But if I am just cruising at 35-45 in 5th, there is a definite vibration. If I pop it out of gear and coast, there is no vibration, if I let off the gas in gear the vibration goes away and if I give it MORE gas (by pushing the pedal further) the vibration also disappears.
As far as work recently I mounted a push bar, flushed my front diff with Royal Purple, and did right side caliper, pads, rotor, bearings and seals.
I honestly have no idae where to start.
Thanks!
Thanks!
I would think U joint as well but its a tough one, I would try getting under the truck and rocking it back and forth in gear (I lay on my back and push the car forward with my feet)to see if the ujoints have any slop in them, often you will see a little play when the vehicles weight shifts if they are warn.
ConradLeo
06-22-2013 09:02 AM
Shane83
12-10-2010 06:14 AM
rod97rvr
12-19-2009 08:39 PM
khtemple
09-14-2006 06:00 AM
