Weird vibration- help!
Old Jan 20, 2011 | 06:07 PM
Garrett's Avatar
Default Weird vibration- help!
So yesterday I noticed a very weird vibration when driving my D1. It doesn't do it, to my knowledge, when I accelerate. But if I am just cruising at 35-45 in 5th, there is a definite vibration. If I pop it out of gear and coast, there is no vibration, if I let off the gas in gear the vibration goes away and if I give it MORE gas (by pushing the pedal further) the vibration also disappears.
As far as work recently I mounted a push bar, flushed my front diff with Royal Purple, and did right side caliper, pads, rotor, bearings and seals.
I honestly have no idae where to start.
Thanks!
Old Jan 20, 2011 | 07:09 PM
Sounds like a u-joint to me.
Old Jan 20, 2011 | 07:53 PM
Garrett's Avatar
Also, at highway speeds it is not there. I remember the PO telling me he changed the drive shaft to one from a ~98 D1? Would that make sense? I emailed him either way.
Old Jan 20, 2011 | 08:15 PM
Rover Chris's Avatar
I would think U joint as well but its a tough one, I would try getting under the truck and rocking it back and forth in gear (I lay on my back and push the car forward with my feet)to see if the ujoints have any slop in them, often you will see a little play when the vehicles weight shifts if they are warn.
Old Jan 20, 2011 | 08:17 PM
Garrett's Avatar
That's a funny image in me head I'll give it a try.
Old Jan 20, 2011 | 08:25 PM
groundandpound's Avatar
X3 on the U-Joint.
Although, with recent brake work, you might want to bleed them as I have had strange things pop up when I have had air in my lines...
ConradLeo
Jun 22, 2013 09:02 AM
tonyp71
Jan 13, 2008 08:46 AM
khtemple
Sep 14, 2006 06:00 AM
