What are 1998 Disco Jump Seats worth?
Old Apr 30, 2012 | 09:03 PM
  #21
Sam95disco's Avatar
Originally Posted by Spike555
I have found that mine reads differently depending on the brand of gas I use which I figured out is directly related to the amount of ethanol in the fuel.
Sam, throw a 5gal gas can in the back with a funnel, drive until she quits and see see how much gas you can put in.
If your gas tank is dented it will hold less fuel.
Its not dented, but I'll remove the pump and see whats up. Right now its on E, but light is not on. Since she's down with her heads off. I have time to fool around.
Old Apr 30, 2012 | 09:30 PM
  #22
nelsontod's Avatar
Yes diesel oil, just because it is not a diesel engine means nothing.
You live in Minnesota, it gets cold there in the winter, use 5w-40.
Go to Wal-Mart, Shell Rotella 5w-40, its in a blue jug, buy two jugs, you need 7 qts for a single oil change.
Then go to NAPA and buy a NAPA oil filter, the middle grade filter will be best but the lower grade one will be fine too.
Dont waste the money on the top of the line one.
Make sure you grease all the u-joints and slip joints on both driveshafts each and every oil change.
how many pumps with a grease gun do these u joints and slip joints take? dont want to over grease?
Old Apr 30, 2012 | 09:33 PM
  #23
You cannot over grease, once new grease comes out of all four corners of each u-joint move onto the next one.
When new grease comes out of the gaitor on the slip joint it is done.
If the u-joints will not take grease gently tap on the end caps with a hammer, then try again.
Old May 1, 2012 | 08:36 PM
  #24
Danny Lee 97 Disco's Avatar
That huge Mann Oil Filter is only 6 bucks Purolator L43something...........
Old May 1, 2012 | 08:40 PM
  #25
nelsontod's Avatar
Not following ya......?
Old May 1, 2012 | 10:14 PM
  #26
filbs's Avatar
Thumbs up
Purolator L40316
Old May 2, 2012 | 01:29 AM
  #27
FlyingZebra34's Avatar
I just wanted to add, once these trucks rolled off the lot they lost a lot of value
Old May 2, 2012 | 08:03 AM
  #28
filbs's Avatar
just like anything...
Old May 2, 2012 | 08:41 AM
  #29
slanginsanjuan's Avatar
what are jump seats worth? they say "landrover" more than a Camel Trophy badge.
the memories....kids, drunks and mother-in-laws. priceless.
Old May 2, 2012 | 08:45 AM
  #30
nelsontod's Avatar
got it. their staying in.
C.O.R.E.inMinnesota
Off Topic
Nov 12, 2013 03:40 PM
C.O.R.E.inMinnesota
Nov 7, 2013 06:16 PM
doctorcooper
Mar 4, 2008 05:00 PM
Buf1572
Jul 13, 2007 07:42 AM
modelwerks
Sep 19, 2005 03:59 AM
